heat fluctuation
Old Apr 9, 2006 | 02:30 PM
Tesch101's Avatar
Tesch101
heat fluctuation
I've got a 1984 F-250 with a 351W 4bbl. I've been having overheating problems. If I run the truck with the climate control selector in the 'off' position the temperature stays in the normal range with small movements depending on how hard i run it. If i move the climate control selector to any other position (heat, vent, AC, defrost, ect.) the temperature quickly rises and the truck overheats. I replaced the thermostat, twice. radiator and the clutch fan and there are no leaks in the hoses and the water pump pumps. I've never had problems with a heater core. could there be a problem with it? I always thought that if you turn the heat on the temperature of the truck should drop not rise. any ideas?
