Water temperature Guage
Old Oct 8, 2002 | 09:48 PM
Joey1986Z's Avatar
Joey1986Z
[updated:LAST EDITED ON 08-Oct-02 AT 10:55 PM (EST)]Mine does not work. Any suggestions are appreciated.
1971 F100 302 c.i.
Old Oct 9, 2002 | 06:46 AM
William's Avatar
William
Find the sending unit on the engine, turn on the key, ground the sending unit wire to the block. Does the gage move up and peg? If the gage pegs, replace the sending unit. If the gage does not move check continuity in the sender wire, fuses and the voltage limiter on the dash panel behind the gages.
William in Atlanta
Old Oct 15, 2002 | 07:04 PM
Joey1986Z's Avatar
Joey1986Z
Thanks, A month back I hooked an ohmmeter to the sending unit and noticed the resistance changed as the engine warmed; however, I did your ground trick and the needle pegged, so I'll be getting a new sending unit.
Thanks!
Old Oct 15, 2002 | 08:24 PM
69crewcab's Avatar
69crewcab
