2 quick questions...
Old Apr 9, 2006 | 07:12 AM
BigAlVB's Avatar
BigAlVB
1. Where can I find the prepackaged relays that bump up voltage to headlights. I don't want to make my own.
2. Where can I find stock rims for our year trucks (a full set of 4 in GREAT shape)? The ones with the 10 or so holes. How big of a tire will they fit? Would a 33x12.50 width work OK or not?
Old Apr 9, 2006 | 07:34 AM
water 5's Avatar
water 5
why do you want to bump up voltage to your headlights?
the stock size is 15x7 for the rim try this web site if you go to the tire calculator on the left side and fill out the info it will tell you the rim range you can use if that helps.
www.1010tires.com
Old Apr 9, 2006 | 08:35 AM
18fan's Avatar
18fan
I think this is the headlight kit you are talking about.http://www.lmctruck.com/icatalog/fd/0050.html
