backing plate removal
Old Apr 8, 2006 | 02:42 PM
rex78's Avatar
rex78
Question backing plate removal
I'm trying to swap out the backing plates on my 78 f150 with a Ford 9inch rear end. I thought that once I pulled the axle I'd be able to just slide the backing plate off, but the bearing , or maybe just the seal, is in the way. Does anyone know if I am going to have to remove the bearing and if so what tools do I need?
Old Apr 8, 2006 | 06:28 PM
lasthighboy's Avatar
lasthighboy
if you are talking abot the brake backing plate, i think it should be able to pull off after you pull the axle
Old Apr 8, 2006 | 06:41 PM
rex78's Avatar
rex78
Yes, that's what I thought as well. But it looks like the outer seal is stuck in the brake backing plate and preventing the plate from pulling off. I'm afraid to just start whacking on it because I don't have a new seal to replace the old one. Or should I be replacing the seal anyway?
Old Apr 9, 2006 | 08:18 AM
lasthighboy
it is usually a good idea to replace the seal anyway. not saying i have always done it, but u should. they arent that expensive anyway
Dec 27, 2014 09:31 PM
jasonodsky
Oct 9, 2014 12:23 AM
Nazty 4X4
Jun 20, 2014 07:17 AM
Boba Fett
Dec 22, 2009 03:42 PM
jecsd1
Jun 16, 2008 03:00 PM
