Tailgate position-does it affect mileage?
Hope this helps
Original link: http://www.enjoythedrive.com/content/?id=10651
another link http://www.dynoproducts.net/fuel&air...ausavesgas.htm
Q: Jerry found us on the web and writes: I read an article from the University Notre Dame concerning wind tunnel testing of pickup trucks. They said that pickups with tailgates up had less drag than trucks with gates down or with "air gates". The reasoning is that the closed gate creates a bubble of stagnant air that dynamic air passes over, therefore lowering overall drag. I suggest you research. If I am correct, please ammend your article on being kind to the environment. Please let me know what you think.
A: SEMA member company Pace-Edwards Co. (2400 Commercial Blvd., Centralia WA, 98531, 800-338-3697, www.pace-edwards.com), makers of pickup bed tonneau covers, recently sent us the results of aerodynamic testing on pickup trucks performed at the Western New England College School of Engineering. The test results were quite illuminating, so we thought we'd share them with you.
At Western New England College, Todd Ortolani and Vanwijak Ewosakul, under the leadership of Dr. Alan Karplus, an in-depth study on the effect of airflow once it passes the truck's cab was performed. The flow separates behind the cab and enters the truck bed resulting in a drag coefficient (Cd) of Cd = .432 if the bed is not covered. When a square truck cap is added, the drag coefficient increases to Cd=.480, or an 11.11% increase in drag.
When a tonneau cover is used, the drag coefficient decreases to Cd=.381, or an 11.81% decrease in drag. Additional comparisons were made in the study by changing the tailgate. Replacing the tailgate with a cargo net resulted in Cd=.461, a 6.71% increase in drag compared to removing the tailgate which resulted in a Cd=.447, a 3.47% increase in drag. Also, lowering the tailgate resulted in Cd=.414, a 4.17% decrease in drag. The results of this study concluded that the best method of decreasing the drag coefficient, thus increasing fuel economy, is to install a tonneau cover over the truck bed.
Please note that the results from this test do not agree with the results you have cited. It's not a great mental stretch to understand that different makes and models of trucks are likely to produce different results, even in the controlled environment of the wind tunnel. We would fully expect to see, for example, that a truck with a standard bed and the same truck with a step-side bed, would have different results. Additionally, different brands of pickup trucks will have different configurations in the tailgate area.
Some trucks have a slight amount of "wrap around" in the rear corners of the bed where the side wall of the bed actually forms a small upright section as it turns the corner to meet the tailgate. In other trucks, the tailgate spans the entire rear section of the bed, and when opened, it leaves no upright section at the rear of the bed. Would these two designs post different drag coefficients?
Furthermore, would it also not be possible that the length of the bed plays a part in all of this? Certainly a truck with an eight-foot bed is going to post different results than a truck with a six-foot bed. That being the case, what about the new crop of four-door pickups that have beds under five feet in length?
As far as air gates are concerned, the Western New England College study found that the drag coefficient increased with its use by Cd= 0.029. This would seem to bear out the results of the test you are quoting. But this does not take into consideration the weight advantage the air gate enjoys over a standard tailgate. A standard tailgate weighs 40 lbs. or more depending on the truck. An air gate weighs about 8 lbs. with its attaching hardware. While they create more drag according to these tests than a standard tailgate, a 32 lb. weight advantage has to count for something when measuring fuel economy, which is really what we were talking about in the first place.
Weight is a very serious consideration when talking about fuel economy. If we could build two identical pickup trucks, one with an all steel bed, and the other with a lighter fiberglass bed assembly, even though they have the same coefficient of drag, wouldn't the lighter truck get better mileage?
This then begs the question, how much would we need to improve the coefficient of drag of the heavier truck to match the advantage the lighter weight truck enjoys? Pace-Edwards has shown that the use of their tonneau covers lower the coefficient of drag on their test truck by Cd=0.051 or 11.81% over an uncovered bed with the tailgate up. Additionally, they have testimonials from users of their products that they have noted improvements in fuel economy since installing their tonneau covers on various makes and models of trucks.
The point of all these cerebral calisthenics is that test results like those we have quoted, and you have cited, can vary widely. Do the companies that say their products improve aerodynamics have test results to back up their claims? Some apparently do, while we can not speak for others.
Older trucks that were not wind tunnel tested are anybodies guess. However simple variation of driving habits are likely to be high enough to obscure any difference. I'm going to leave mine up. Makes it easier to show the big FORD on the tailgate to rice burners and chevys that can't keep speed uphill.
