squeel and drop
Old Apr 8, 2006 | 10:41 AM
wildangelford's Avatar
wildangelford
squeel and drop
I have a 2002 edge that squeels when hot, and yesterday the oil pressure gage dropped to 0 then back to normal. I took it on a long trip two days before with no problem. PLEASE help! email me back @ jackieaherr @ yahoo.com
</XBODY><!-- toctype = X-unknown --><!-- toctype = text --><!-- text --><!-- toctype = message --><!-- toctype = X-unknown --><!-- toctype = text --><!-- text --><!-- END TOC -->
Old Apr 8, 2006 | 10:49 AM
RangerPilot's Avatar
RangerPilot
Ok...welllllll. The oil pressure "gauge" is nothing more than a glorified dummy light. At 8 PSI, it jumps to "normal", below 8 PSI it sits on low or wherever. So you're oil pressure is ridiculously low, and running it like this for almost any time at all is going to signal the end of that engine.
When was the oil changed last? How is the oil level? If the oil level is good, I'd suspect the oil pump.
What engine do you have? The 2.3 four cylinder, 3.0 V6, or 4.0V6?
Old Apr 8, 2006 | 06:13 PM
dono's Avatar
dono
Gone but not forgotten.
Jackie, this is not something you should ignore. Anytime you have noise and low oil pressure it is time to have a pro look at it. Good luck.
Dono
Old Apr 9, 2006 | 03:08 PM
wildangelford
Yeah
I know. I already have -Yesterday. They said bad belt and ? on the oil pressure. Seems it is working properly now.
