parts swap
Old Jun 5, 1999 | 06:03 AM
Rob's Avatar
Rob
parts swap
Old Oct 18, 2002 | 05:17 PM
Goodold71's Avatar
Goodold71
Post parts swap
I have a 71' F-100 4x4 . I want to install a 6" suspension lift and eliminate the blocks. No one makes the springs for my year so I decided to swap in springs off a 76-79 model truck. Will this work if I use the hangers from a 76-79 truck because I can buy springs for these years? I am also wanting to put a 3/4 ton or 1 ton front diff in it so as to eliminate the coil suspension for leaf. And then I want to eliminate the manual np435 trans/Dana 21 t-case that is in it for a c-6 / np205 tcase. I will put a 460 c.u. in it next fall.I guess if it will work I will start looking for a truck with a blown engine that hasd most of these parts......But will this work????? Thanks T
