Sponsored by: Auxito
2000 F-150 missing #8 cyl
Old Apr 8, 2006 | 10:18 AM
Stevemurray's Avatar
Stevemurray
I have a 2000 f-1504x4 that suddenly developed a miss. It is mostly in the idle circuit or mid throttle range. It makes the truck buck pretty bad. If you get in the throttle, it seems to come out of and has power. The check engine light is on. I took it to Autozone, the scanner read misfire #8 cylinder. Some research has suggested the COP may be bad. When the engine cold, it runs fine for avout a mile before starting to buck. Sound familiar to anyone?
Old Apr 8, 2006 | 01:26 PM
Stevemurray
correction- this is a 2001 f-150 4x4
Old Apr 8, 2006 | 05:11 PM
lariat97's Avatar
lariat97
Its a common problem on the 5.4s. I've replaced 2 on mine.
Old Apr 8, 2006 | 09:09 PM
maticuno's Avatar
maticuno
Yep. I'd put my money on a bad COP. I've replaced quite a few.
Old Apr 8, 2006 | 10:50 PM
Stevemurray
Thanks a lot guys. I appreciate your input on this. I called Ford and priced a coil. It cost over a hundred, so I didn't want to but one until I knew more. I feel I can get one now and try it. I'll let you know how it comes out.
Old Apr 9, 2006 | 06:56 AM
gfreek's Avatar
gfreek
That seems alot of $ for that. Aftermarket COP at Carquest is $70.00.
Old Apr 9, 2006 | 08:42 AM
projectSHO89's Avatar
projectSHO89
AutoZone - $50.
Steve
