Auto trans filter change...
Old Apr 8, 2006 | 09:54 AM
vls's Avatar
vls
I have a 79 F250 with a C6 trans. It overheated the trans last year hauling a load of drywall (started making a low squealing noise). After it cooled, it did fine, but as soon as the snow is gone (it's my plow truck) I want to replace the filter/fluid. Do I need to have all of the fluid flushed, or can I just replace what I lose changing the filter? Never do much freeway driving, but do a lot of stop and go plowing and load hauling.
Old Apr 8, 2006 | 11:46 AM
Craigster1's Avatar
Craigster1
I would change all the fluid.
On my 78 C6 there is a 2”X3” door at the bottom of the bell housing held on with a sheet metal screw. Remove the little door and turn the flywheel over until you see a ¼” pipe plug in the torque converter. Removing it will empty the converter (its slow). Remove the pan and be ready for a mess. Flush out the cooling lines. Replace the filter and gasket. Fill and check level. Before you start be sure you have enough ATF and the right filter/gasket set.
Its not tough but can be a messy job.
Old Jun 8, 2006 | 02:09 PM
seventyseven250's Avatar
seventyseven250
So, how much fluid would one of these take if you emptied it out as Craister suggests?
I'd prefer to have enough fluid on hand.
Old Jun 8, 2006 | 04:00 PM
Mil1ion's Avatar
Mil1ion
The answer is in the Drivetrain forum
23.5 US pints.
Their pints are 16 oz.
ours are 20 oz
Old Jun 8, 2006 | 05:49 PM
unrulee's Avatar
unrulee
Why can't pints be pints where ever you are!
Old Jun 8, 2006 | 06:02 PM
MBBFord's Avatar
MBBFord
I did this to my 79 Bronco's C6 a few months about, and it COMPLETLY drained. I want to say it took about 8 quarts to fill it up again. While I was down there, I got a new Chrome pan from ebay for $15 shipped to my house. The chrome pan does nothing for the truck, but every time I crawle under there I have to laugh b/c it is so out of place(a big shinny pan while everything else is coverd in dirt, mud, grit, grim, ect...).
