Swapping Rear Axles
Old Oct 18, 2002 | 12:53 AM
user 5363849's Avatar
user 5363849
Post Swapping Rear Axles
Can a 71 F-100 use a rear axle from a 73 F-100? I know that the track is different but otherwise they seem awfully similar.
Are there many variations on the gear ratio? My 71 has an automatic and the 73 has a 3-sp manual. But I imagine that they're both 1:1 in third gear.
Old Oct 18, 2002 | 05:21 AM
jowilker's Avatar
jowilker
Swapping Rear Axles
Daniel, In 73 Ford widened the rear track so 72 is the last year that an axle swap will work, even though the center section can still be swapped fron newer models. You will have to check for big bearing or small before buying your new axle. Count the splines for 28 or 31 teeth.
All trannys have a 1 to 1 output in high gear that are not over or under drive. Rear end ratios for street run from about 2.75 to 4.11. The lower numbers are for crusing and the higher for pulling.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Oct 18, 2002 | 07:22 PM
oughtsix's Avatar
oughtsix
Swapping Rear Axles
Through '72 the rear frame rails were 34".
'73 and newer the frame rails are 37 1/2".
You will need to move the spring perches from a newer axil in.
Old Oct 19, 2002 | 04:02 AM
jowilker's Avatar
jowilker
Swapping Rear Axles
oughtsix, You would have to do your recomandation to swap the rear end not the axle.
John
jowilker email me
Old Oct 21, 2002 | 12:43 AM
mlf72f250's Avatar
mlf72f250
Swapping Rear Axles
Old Oct 21, 2002 | 11:22 AM
oughtsix's Avatar
oughtsix
Swapping Rear Axles
YEP! You are correct, I misread the post.
dagomachining
16
Jun 27, 2013 09:37 PM
71'3604speed
Sep 3, 2012 04:44 AM
planesrhino
Mar 20, 2007 07:57 PM
Broke_Okie
Nov 14, 2005 12:10 AM
Randle
Nov 23, 2004 06:38 AM
