Sponsored by: Real Truck
Front License Bracket Mounting?
Old Apr 7, 2006 | 07:12 PM
wdglide's Avatar
wdglide
My 2004 F250 had no front license bracket mounted to it when I purchased it. I picked up the bracket from 1st Ford Parts. I can't figure out how it mounts.
Any chance a kind soul could snap a photo of the backet from below -- looking up?
I believe I am still missing parts. Mine only came with the license plate holder. Looks like there should be two other brackets that affix to the bumper and clip to the bracket. Photos would help.
I searched the gallery, but no photos showed it from a good angle.
TIA
Phil
Old Apr 7, 2006 | 08:52 PM
n578md's Avatar
n578md
The bracket appears to be a one-piece affair held by 4 plastic push-pin type fasteners which are going through 4 holes on the under side of the bumper and plastic bumper shield.
3/4 view:
https://www.ford-trucks.com/user_gal...112881&width=0
2 fasteners per side:
https://www.ford-trucks.com/user_gal...112882&width=0
Full view:
https://www.ford-trucks.com/user_gal...112883&width=0
Old Apr 7, 2006 | 10:52 PM
sltrrco's Avatar
sltrrco
Do what I did Drill out the holes and and bolt it to the bumper with grade 8 bolts. It will never come off.
Old Apr 8, 2006 | 04:48 AM
Studenut65's Avatar
Studenut65
I also put bolts on mine - the plastic push pins are too weak for a front license bracket that sometimes get whacked with off road driving, etc.
Nate
Old Apr 8, 2006 | 07:59 AM
wdglide's Avatar
wdglide
Thank you very much!
Looks like they sent the wrong part. This is what I was sent.
https://www.ford-trucks.com/user_gal...112947&width=0
Old Apr 8, 2006 | 12:25 PM
CobraGT40's Avatar
CobraGT40
Nate
If I had a nickel for every time I lost my front license plate...I'd have a @#$%-load of nickels...LoL
Scott
p.s. I never was able to find out how the dang push-pins worked...So I just used some nuts&bolts from the hardware store...no worries!
Old Apr 8, 2006 | 01:12 PM
SpringerPop's Avatar
SpringerPop
Here in Los Angeles, I use tamper-proof Torx 1/4 inch bolts and Loctite.
Same for the rear.
They ainn'a comin' off unless I WANT 'em off!
Pop
Old Apr 8, 2006 | 01:20 PM
wilbur996's Avatar
wilbur996
I had to buy a license plate bracket for my 99 SD. The guy at ford gave 4 plastic rivets to hold it on. At first I thought they were push pins but they are actually 1/4" plastic pop rivets. They hold pretty good.
smithrock
27
May 22, 2012 04:34 PM
KodiakF250
Mar 7, 2012 12:34 AM
carprojects
May 7, 2010 05:47 PM
cdaily91
2004 - 2008 F150
Dec 13, 2008 11:24 AM
