Updating a 351W
Old Apr 7, 2006 | 12:57 PM
spacejesus's Avatar
spacejesus
Updating a 351W
I have a older Carburated 351W that has just been rebuilt, both block and heads, is there a way to make it fuel injected by using all Ford EFI parts and what would I need?
Old Apr 7, 2006 | 01:01 PM
spacejesus's Avatar
spacejesus
This was rebuilt to OEM Specs, with new stock everything.
Old Apr 8, 2006 | 08:02 PM
mauicruza's Avatar
mauicruza
Try to get all your parts from one donor vehicle if possible. Get everything from upper and lower intakes to harnesses and ECM. Check ebay, but you'll mostly find truck style efi systems for the 5.8w. Take into consideration that the truck style intake is much taller than your carb set-up so check your hood clearence. You'll still need to plumb the fuel system for the high pressure and return line and other odds and ends.
