Idel problems??
Old Apr 6, 2006 | 10:59 PM
Dmartin_1's Avatar
Dmartin_1
Question Idel problems??
Well I'm back I need to know if there a was to set the Idel down? 5.0 Efi Yust rebuilt it and installed a 1978 lincoln roller cam engine in it now it idles to fast.Can slow it down with the timing but it loose to much power.Thanks
Old Apr 7, 2006 | 09:20 AM
Dmartin_1's Avatar
Dmartin_1
HELP Please . I Just used the Lincoln block and heads. Everything else was 1991 F150 . Yes I did change the gear on the dist. for roller cam.
Old Apr 7, 2006 | 09:27 AM
Kemicalburns's Avatar
Kemicalburns
dont touch the idle screw. check for vacum leaks, when you set the timing was it done with the spout connector out and at 10*btdc? what cam are you running and its specs. and are you running the stock 91 efi system?
Old Apr 7, 2006 | 10:31 AM
Dmartin_1's Avatar
Dmartin_1
Roller cam from 87 Lincoln. stock 91 efi system . What is a spout connector? 10* ? Maybe I need to tane it to a shop for that.1 piece at a time F150
( 1987 lincolon motor ,1995 F150 5 speed transmission) was a Automatic.all most done tho.
Old Apr 7, 2006 | 12:58 PM
Dmartin_1's Avatar
Dmartin_1
Found problem bad vacume line on the troddle body thanks Danny
