Brake troubles
Old Oct 21, 2002 | 10:57 PM
speedking390's Avatar
speedking390
Brake troubles
I was working on my truck today routing the new brake line and when I got some help to bleed the brakes we could not get the fluid to come out of the brake bleeder screw hole any suggestions
Steve
P.S. When I hooked it up I bypassed the brake modulator thingy would that have anything to do with it.
1970 f-100 Custom 302 2bbl 4 on the floor, my "economy" machine 1970 F-100 Sport Custom 390 2bbl 3 in the tree with factory overdrive.
1978 F-150 Custom turned into a dune buggy 300-I6 4 speed
Im a typical teen, i just have to change it!
Old Oct 24, 2002 | 09:07 PM
rebocardo's Avatar
rebocardo
Brake troubles
I would guess one of three things, #3 most likely:
1) The wheel cyl. is so old and broken that the inside is stuffed full of congealed brake fluid and rust that is preventing it from coming out of the bleeder.
2) Major piece of rust/metal caught inside of bleeder screw.
3) Badly rusted bleeder screw, where it is rusted solid inside the wheel cyl. You are actually twisting the top of the screw while the bottom stays in place. If you take it off the truck, put it in a vise, apply WD-40, and work it slowly back and forth, you might free it and can then insert a new bleeder screw. I have had roughly a 50/50 success rate doing this off the truck. None with it on the truck.
Old Oct 24, 2002 | 09:27 PM
Fordzlla's Avatar
Fordzlla
Brake troubles
chefcharles
Dec 9, 2014 12:11 PM
86ford302help
27
Apr 4, 2013 10:19 PM
speedking390
Nov 27, 2011 01:30 AM
speedking390
Alberta Chapter
Dec 15, 2002 11:52 PM
speedking390
Oct 5, 2002 07:53 PM
