3-speed overdrive transmission
3 speed overdrive
These are getting more difficult to find. I saw a used one last week go for 200 on ebay, and it needed rebuilt. I'm picking one up in the next couple of days at the boneyard for 250. I had searched another yard, but found only the light duty version (borg warner t-86), they also had a couple chevy units. I was searching for the t-85. I guess it's possible to get one from a chevy which seems to be more available, and adapt the overdrive portion of it to your ford manual transmission.
I believe the borg warner t-86 was for smaller engines and the t-85 was for the big blocks. Someone correct me if I'm wrong.
I paid $250 for mine about 7 years ago, took me forever to find one, and then found out a part in the OD was bad and had to search for it...but when finaly done I love it..its in my 60 behind a 223...be sure you find one that has a working solenoid, they can cost you as much as a trans...
saw this one on ebay
Here's the one you want, don't see them too often, you didn't say what engine you have but this looks like the later model wide bolt pattern.....
http://cgi.ebay.com/ebaymotors/T85N-...QQcmdZViewItem
OD gear operation
How would/could a person engage/disengage this OD. I understand that you flip a switch to engage/disengage the OD, but would need to let off the gas in 3rd, then engage? At what rpm? Can this be used in all gears (not that it would be needed, just asking). Are these like gear vendors OD's, just older? Thanks for the clarification.
Dan
Dan
RON..it takes more than fab of a new pilot bearing, if you don't use on out of a pre1965 truck you also have a problem with the throw out bearing, you'll end up with a small input shaft collar and a fork in the early bellhousings won't work, and the shorter input shaft also wont totaly engage the clutch disc..
DAN...I don't have a complete electrical system for my overdrive ( kickdown switch, relay and governer) so I just use a toggle switch direct to the solenoid..you can shift it at any rpm by throwing the switch and momentarily letting off the gas to drop engine rpm...you can do it in a three speeds, so it actually gives you six speeds..but this is a dangerous practice unless you know what your doing, you could find yourself in freewheeling with only the brakes to stop...
Classicdriver
12-24-2016 11:34 AM
1966, 3speed, aftermarket, borg, clark, f100, ford, od, overdrive, speed, t86, trans, transmission, transmissions, warner
