expedition with 4.6 power question
Old Apr 6, 2006 | 07:52 AM
Mikes67F250's Avatar
Mikes67F250
I have a 99 expedition with a 4.6 full time 4wd. Will de using it to tow a car and trailer about 1000 miles. And I will be using it on other fishing trips and such with a heavy boat.I know I can do something with a computer chip or something to get more power and torque out of it. But is it a noticeable difference. I know that at times you can get better gas milage to by doing this, I believe?? Can anyone help give me some insight on this??? I sure would appreciate it. Can this motor take the trip towing car and trailer that far without pushing it to far???? Thanks
Old Apr 6, 2006 | 11:20 AM
pronstar's Avatar
pronstar
So long as you are within the factory towing limits, you should be fine.
Do you know what your rear-axle ratio is?
I may sound like a broken record, but rear gears play a big - and definitely noticeable - role in towing. Especially if you have a 4x4 with large, oversized tires.
Do a quick search, there's a few posts on how to determine what your rear-axle ratio is.
