Do any of you guys with 8 inch lifts regret going so high?
Do any of you pull a trailer with it?
How much did it cost to get new driveshafts redone?
In the end is it worth it?
I was thinking of an 8" with 37's if I could get away with it I might do a 6" instead if I can still fit the 37's without rubbing. This is for a 2004 V10.
If you want 37's, go with the 8" lift. I run a 6" Skyjacker on mine with 36's and do get a little rub (on the fender liner) when I stuff the tires in a turn.
