Sender instalation
Old Apr 6, 2006 | 12:01 AM
Myckel's Avatar
Myckel
Exclamation Sender instalation
I'm adding a transmission and oil temp. senders on an V10, has any of you done this and what is the best locations and what is the best way to do this, do I drill holes and tab the sender into it?
Any Ideas?
Please help
MW
Old Apr 6, 2006 | 05:24 PM
VX-23 Hokie's Avatar
VX-23 Hokie
There's a test port in the transmission that the sender will fit in. Get under the truck and look at the driver's side of the transmission - you'll see the shifter. Just forward of the shifter and up a little bit is a plug for the test port (its just a bolt with fine threads). Remove the plug and install the sender (it's the same size/thread). I've heard of some peolple having problems with the sender bottoming out in this location and breaking off in the transmission. I tested mine for adequate depth by removing the plug and inserting a drill bit with the same diameter. I had plenty of clearance for the sender. The sender has pipe threads so it will feel tighter the further you install it - this is normal. If you have trouble locating the test port let me know and I'll send you a picture of it.
I haven't installed an oil temp sender.
