Guide plates
Old Apr 5, 2006 | 10:09 PM
1low50's Avatar
1low50
Guide plates
I have a set of 289 heads with the oval port that the pushrods go through. I am getting screw in rocker studs installed and am going to be using roller rockers. Do I need guide plates in these heads or will I be okay?
Old Apr 6, 2006 | 08:45 AM
TigerDan's Avatar
TigerDan
The early (up to mid-'66) 289 heads with the small pushrod holes don't need guideplates as the holes themselves act as guideplates, with the two flat sides being very close tolerance to the pushrod.
Just be sure to use hardened pushrods.
