Sponsored by: Real Truck
Door switch sticking....
Old Apr 5, 2006 | 09:42 PM
PAUL351W's Avatar
PAUL351W
One of my door switches has been sticking and the dome & door ajar light is staying on.
Where are the switches at on an extended cab 99 F250? I already sprayed some oil in all the latches on both the main doors and the rear doors, I'm not sure its fixed yet, and its driving me nuts.
Old Apr 6, 2006 | 12:46 AM
zx250's Avatar
zx250
Of the next Riffraff East
Common problem with simple fix. Spray some WD40 into the latching mech. on the doors affected. Work the latch a few times and that will do it. Switch is mounted on the latch itself. Dirt and grim causes the to stick. WD40 will clean and lube it. Fixed mine almost 2yrs ago and still no problem.
Old Apr 6, 2006 | 06:47 AM
Zip's Avatar
Zip
I had the same problem with mine. I ended up having to pull it out to clean it up. Works great now
Old Apr 6, 2006 | 07:14 AM
zx250's Avatar
zx250
Most of the time the WD40 will do the trick. Spray plenty. It's not going to hurt any thing. Just runs out the bottom.
Old Apr 6, 2006 | 09:15 AM
wiingnut's Avatar
wiingnut
wd40 fixed mine
Old Apr 6, 2006 | 07:04 PM
PAUL351W's Avatar
PAUL351W
Is the switch in the front door only, or are there switches in the swing out doors as well?
Old Apr 6, 2006 | 07:08 PM
zx250's Avatar
zx250
The switch is in the back door latch. Just spray around inside the latch and that will do it.
Old Apr 6, 2006 | 07:11 PM
PAUL351W's Avatar
PAUL351W
Back door meaning where? There are 2 latches in the rear doors, and one in each of the front doors. I'm assuming its the latch in the main doors?
Old Apr 6, 2006 | 07:31 PM
zx250's Avatar
zx250
My bad, I must of had a brain fart. It is the latch on the front door. switch is mounted to it. The latch rotates closed when it strikes the back door, thus releasing the switch when not stuck. Just spray the black latching mech mounted on the inside of the door giving the problem. Sorry for the confusion.
