E4OD computer location
Old Apr 5, 2006 | 08:40 PM
7.3burnoutbuddy's Avatar
7.3burnoutbuddy
Cool E4OD computer location
I need some help here i need to find my computer for my trans. I dont know where it is it must be hiding. These stupid electrical issues are just killing me. thanks.
Old Apr 5, 2006 | 08:42 PM
7.3burnoutbuddy
I forgot to say it is a 1990 F250 with the 7.3 diesel E4OD. thanks
Old Apr 6, 2006 | 12:12 AM
PLC7.3's Avatar
PLC7.3
If you look under the brake booster you will see an electrical plug with 60 wire holes that is the PCM plug so it should be close by inside, unless your PCM is remotely located.
Old Apr 6, 2006 | 04:18 PM
Hamberger's Avatar
Hamberger
I got and 91 F350 and both the tranny controller and ABS controller are located behind the lower dash panel to the right of the steering column.
