Sponsored by: Kumho
Ball Joints Help
Old Apr 5, 2006 | 08:04 PM
76f150_4x4_360fe's Avatar
76f150_4x4_360fe
Ball Joints Help
Hey fellas, all of my ball joints (the steering linkage ball joints and the ball joints on the knuckles) are pretty bad and need to be replaced. Being that I just ordered some 33s I figure I better git r done quick. So my question is, what is the best way to go about pulling them. At one time I pulled a knuckle and tried smackin a ball joint out with a hammer but couldnt git r. I know that is the wrong way so what is the right? Is there a special tool. I do have a pickle for and can get them apart but I need them out of the knuckles and steering linkages. The help is really appreciated. Oh, btw its a 76 f-150 4x4, just incase you didnt look at my name.
Old Apr 5, 2006 | 10:17 PM
mattd17's Avatar
mattd17
yes, you will need a ball joint puller. they are a press fit in the knuckle, and the puller doubles as a remover/installer. most parts stores will sell them, and its easier and cheaper just to buy your own, rather than have a stealership do it for you.
Old Apr 6, 2006 | 04:31 AM
jasonschwenk's Avatar
jasonschwenk
i just did mine and autozone will rent you all the tools for free!
you pay them and then they give you back the money when you bring them back
Old Apr 6, 2006 | 07:07 PM
andym's Avatar
andym
Haha, they're a lot of fun to do. Yes, you will need a ball joint press, for rent at autozone. You'll also need a BFH and at least a can of penetrating oil. The steering linkage will be the easy part - you just bang it out for the most part. The ball joints require lots of disassembly of the front end. I'd pick up a haynes manual if you don't already have one.
Also - do NOT use heat on the knuckle. You'll ruin the temper and weaken the metal.
Old Apr 6, 2006 | 09:13 PM
jasonschwenk
if you do a search in the superduty forum there is a great instructions just look a little i can't imagine them being that different from your truck but i am a rookie so i would check
if they are they same the instructions are dead on and have pics
Old Apr 9, 2006 | 02:39 PM
76f150_4x4_360fe
alrighty, thanks bunches fellas. I do have a haynes manual but as far as the front end goes I could dissasemble and reassemble it in my sleep. From my stupidity of not lookin in it the first time. I broke an axle and when I replaced it along with all the seals and bearings but I didnt set the preload right and kept having to redo it until it was right.
Old Apr 10, 2006 | 10:10 AM
1975Ford's Avatar
1975Ford
Here some info on the how to: https://www.ford-trucks.com/forums/s...ht=ball+joints
-buck-
