Hello
Im Installing A Egt Gauge In My 06 F250 Cc. And I Want To Know Where You Tapped Into (1) The Pwr For The Back Light So It Dims With The Rest Of My Dash Lights? (2) Which Part Of The Manifold You Drilled To Put The Sensor In? (3) What Size Did You Drill And Tap?
Thanks
Todd
Ps Thanks For All The Help Guys , You All Help Me Alot And You Dont Even Know It.
Wll I pulled out the light switch and used a test light to locat the "dimming" wire to tap into for the source. I then tapped the pax side manifold towards the back, basically straight up. Not sure the size of the tap off hand. Do a search for EGT and there was a how to web site that had great pics of the process.
