88 E150 Fuel Pressure Relief
Old Apr 4, 2006 | 08:57 PM
CM1's Avatar
CM1
Smile 88 E150 Fuel Pressure Relief
I have a 88 Ford E150 with a 4.9L 300cid engine with dual gas tanks, I need to replace the fuel pump in the rear tank, I have siphoned out all of the gasoline and now need to release the pressure before I disconnect the fuel lines.
Can someone please tell me how to do this?
Thanks
CM1
Old Apr 5, 2006 | 02:59 AM
racinrob's Avatar
racinrob
disconnect the conn at the rail fuel pump or pump relay. crank it a few seconds
if it starts it should stall....then crank it a few seconds more.
reconnect the con. then pull the neg battery cable.
good luck.
CM1
Jul 27, 2008 09:55 PM
CM1
Feb 10, 2006 01:27 PM
CM1
Jan 27, 2006 01:59 AM
