4bbl to 1bbl modification
Old Apr 4, 2006 | 12:13 PM
Twinscrew's Avatar
Twinscrew
Someone inquired about adapting a 4bbl intake to run a stock one bbl carb. I did this several years ago with much success so I thought I would share that here. I started with a dual plane Offy that someone had removed the center divider from. I replaced the divider in a way that opened up the outer plane for use with the 1bbl. I contoured the intake with Duraglass body filler. If all goes well I will attach the pics below. The intake was installed along with a header. The increase in both torque and gas mileage were significant. I ran this combination on one of my F250 tree service trucks. The truck with a loaded trailer weighed in at the county landfill at 15,000 lbs. on a regular basis and acceleration at that weight was impressive. This intake will go back on the next carbed motor I build. OK I can't get these pics to post. Can I get some help?
