DPFE Parts Num?
Old Apr 3, 2006 | 10:04 PM
Taumac's Avatar
Taumac
DPFE Parts Num?
Can someone pls tell me the part num of there DPFE sensor.... Im trying to get a new one but the part num doesnt come up and dont even list a EGR pressure sensor for the 5.4 on FORDPARTS.com I have on mine F7UE-9J460AA. Napa.com. has one but says replaces F7UZ-9J460AA looks the same but not sure?? Alittle confused did Ford change the part num or am I just going crazing??? Any help would be great Thanks
Old Apr 4, 2006 | 04:02 PM
FTE Herman's Avatar
FTE Herman
^He's got a 99 EB (Expy) 4x4 with a 5.4 in case you didn't see he signature.
Old Apr 4, 2006 | 04:43 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
F77z-9j460-aa
Old Apr 5, 2006 | 08:44 PM
WillieWildcat's Avatar
WillieWildcat
AIRTEX Part #5S2040 also will work. It is also called the EGR Pressure Feedback Sensor. I put this one on mine....(and also a new EGR Valve w/Gasket).
If you are up to it, you will need to clean out the entire intake manifold spacer or "elbow". These tend to get very dirty with carbon build-up.
Old Apr 7, 2006 | 05:41 PM
Taumac's Avatar
Taumac
I did the reverse cleaned intake and egr value first and took apart dfpe sensor it had clouge in ref tube and crap all inside. So took a chance on cleaning it out and if it worked cool if not just order a new one. But thanks on replies order one from y2k ford should be here today....they change part num and wanted to make sure got right one
