Can I tow?????
Old Apr 3, 2006 | 05:42 PM
jeffj2689's Avatar
jeffj2689
Can I tow?????
i have a 1996 f-250 with a 351W. it has overload leaves and 33 inch tires. i was wondering if i could tow a car hauler with a car in it. the weight of the car and trailer would be around 3000 LBS. also what upgrades will help with this weight??
Old Apr 3, 2006 | 05:44 PM
Popa Tim's Avatar
Popa Tim
you should be good. My F150 is rated for 3000# on the factory bumper hitch...
Old Apr 3, 2006 | 06:53 PM
77bigblock's Avatar
77bigblock
i pull about twice that with my 92 F250HD. I have 3.55 gears so it is not the best, but you shouldhave no problem. I pulled an F-150 on my trailer this weekend and it was about maxed out on the expressway and hills. Their are two things you want to do: make sure you have trailer brakes and a tranny cooler and you should be good to go.
Old Apr 3, 2006 | 08:21 PM
handyman43358's Avatar
handyman43358
I think you'll be alright. I've got an F-150 (Supposively its an HD, which just gave it the aux. tranny cooler, overload springs, oil cooler, bigger rad, and some other goodies) and I've pulled trucks behind it on a trailer with no problem. Make sure you have the tranny cooler as stated before, and make sure the fluid is good. Trailer brakes are helpful also! 77bigblock pretty much hit it on the nose!
Old Apr 3, 2006 | 11:22 PM
jeffj2689's Avatar
jeffj2689
thanks, my truck already has a trans cooler, and a heavy duty transmision with a shift kit and im putting a brake controler in. i was just wondering if the motor could handle it, but you guys tell me its ok so ill go for it. also do you think a trans temp guage is a good idea??
Old Apr 4, 2006 | 04:19 AM
dgeesaman's Avatar
dgeesaman
The motor is fine. We pull 5000lb horse trailer in an F-150 w/ 351w. Those are some pretty big tires though, so I would check them out in more detail if you ever choose to pull something heavier than that car hauler.
Dave
Old Apr 4, 2006 | 05:44 AM
handyman43358
That engine will do just fine. Not quite as powerful as a big block, but will definately get the job done.
I personally would install a trans temp gauge. What have ya got to lose by doing it? It provides a higher sense of security, knowing you're not going to burn your tranny up!
Old Apr 4, 2006 | 06:34 AM
d_stange's Avatar
d_stange
What gears do you have in the rear? I have the same setup except mine is a 5 speed manual. I pulled a 5000lb skid loader and trailer and didn't have much problem. Had to down shift on a coulple of bigger hills. I'm also running 4:10 gears. Gear ratio plays a big part in towing.
Old Apr 4, 2006 | 04:37 PM
jeffj2689's Avatar
jeffj2689
how to you find out what rear end gears are in a truck??
Old Apr 4, 2006 | 06:15 PM
tomandbeth's Avatar
tomandbeth
Open the driver door, there's a tag on the pillar with the rear axle code. Post it here or look in the articles/specs tab up above.
Old Apr 4, 2006 | 06:17 PM
tomandbeth's Avatar
tomandbeth
also let us know what tranny you have 9code on tag also
Old Apr 5, 2006 | 12:31 PM
jeffj2689's Avatar
jeffj2689
the trans is an E4OD and the axle code is 35
Old Apr 5, 2006 | 12:37 PM
handyman43358
You have a 4.10 rear end, non limited slip. I think you will be just fine towing anything!
Old Apr 5, 2006 | 12:47 PM
jeffj2689's Avatar
jeffj2689
even with the 33 inch tires ill still be fine??
Old Apr 5, 2006 | 12:50 PM
handyman43358
What is the stock tire size on that truck? 265's or 275's?
A 265 tire is pretty identical to a 31 inch tire. I think 285's are close to 33's. So really, you won't notice much of a difference, especially with 4.10's in the rear.
