Upper ball joint
Old Apr 3, 2006 | 01:47 PM
66f14evr's Avatar
66f14evr
Upper ball joint
I have to replace an upper ball joint on my 89 F250 4x4.I"ve never done these before.Is this something I can do myself or am I better off taking it to a shop.But any tips would be great.
Old Apr 3, 2006 | 05:36 PM
Lou Braun's Avatar
Lou Braun
You can do the job yourself if you can get a decent manual and the special tools needed.
Basically you need to remove the brake calipers and tie them out of the way. Then remove the 4WD hubs (special socket wrench) and bearings.
Next remove the spindles. This can be a bear of a job and a slide hammer with the right adapters will save hours of labor.
Remove the front axle stub shafts. Refer to your manual when doing this.
Remove the ball joint fasteners and remove the ball joints. This takes some real effort and the right tools.
Install the new ball joints (do both the upper and lowers). Install the stub shafts and spindles. Use new seals and at least new inner spindle bearings while you are in there.
Reinstall the hubs and wheel bearings and adjust them correctly. Install the hubs and brake calipers. Check out your front brakes while you are doing all this work - now is the time to replace them if needed.
Try the search function on this site. There are some decent instructions here written by savy folk who have done this job several times.
Lou Braun
Old Apr 3, 2006 | 05:41 PM
66f14evr's Avatar
66f14evr
Thanks for the reply.I guess its goin to the shop as soon as i can
Old Apr 3, 2006 | 05:42 PM
Popa Tim's Avatar
Popa Tim
$$ warning $$
It won't be cheap. You may want to consider changing the front universal joints while they're in their also.
Old Apr 3, 2006 | 06:00 PM
water 5's Avatar
water 5
did mine 2 weaks ago pick up a haynes repair manual and rented the ball joint press from the auto parts store it wasn't that bad also have some map gas you will need to put some heat on the old ball joints. it made it easier giting loose and you need a 4 pin socket to get the 2 nuts loose in the hub you can git that also at your auto parts store and some will rent it to you.
Old Apr 3, 2006 | 06:05 PM
66f14evr's Avatar
66f14evr
thats the part that worried me was the specailty tools.So if I can rent them,then thats the way to go.Thanks
Old Apr 3, 2006 | 06:08 PM
Popa Tim's Avatar
Popa Tim
Autozone will loan you them. They bill your cc and credit you upon return fwiw.
bchez
2004 - 2008 F150
May 7, 2014 02:07 AM
Blueheart
Dec 22, 2011 06:41 PM
speced42
Aug 20, 2011 11:07 AM
Sundance Kid
Jan 28, 2010 10:46 PM
bill6302
Jun 2, 2005 07:22 PM
