Suspension?
Old Apr 3, 2006 | 02:15 AM
cobra04's Avatar
cobra04
Suspension?
Hello everyone. I have a 79 F250 4x2 w/ a 460. If I am not mistaken, I can add certain leaf springs to the rear and bigger coil springs up front to get 2-3 inches in height can't I? Anyone have a link to both or know of some that will fit? It sucks it is not a 4x4. There are all kinds of lift kits for those.
Old Apr 3, 2006 | 02:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
You will need a lift kit to do it right. Throwing bigger springs under the front will throw the front end WAY off on geometry. Some guys have messed with it with mixed results.
Old Apr 3, 2006 | 02:48 AM
cobra04's Avatar
cobra04
Hmm...I guess stock it is. I can still add leafs to the rear right?
Old Apr 3, 2006 | 03:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can add leafs but it will make the ride stiffer as well as raise the rear of the vehicle slightly. I would add no more than two leaves. To really raise the rear the springs need to be re-arched or even longer higher arch springs added. Avoid using blocks or you will get some very nasty wheel hop and other bad problems.
Old Apr 4, 2006 | 09:53 AM
quehele's Avatar
quehele
Go to this website and check it out. As far as any of us know, these guys are the only ones that make lift kits for 2 wheel drive Fords.
3" lift: http://www.autofab.com/65-79.htm
5" lift: http://www.autofab.com/5lift.htm
They're not cheap by any means but it's my understanding that they work very well. ClassicMetalMan has one installed:
https://www.ford-trucks.com/user_gal...&albumid=15677
Hope this helps.
Old Apr 4, 2006 | 01:51 PM
cobra04's Avatar
cobra04
I have seen them mentioned here before.. They are pretty expensive though. I think I will just keep it stock for now. Imight add the leaf springs in the back for a little more height.
CrowneVic
Jan 31, 2013 11:46 AM
rockcrawler_101
May 27, 2011 12:08 AM
Greyf100
Aug 17, 2010 08:40 AM
beverett2
Offroad & 4x4
Feb 16, 2005 05:46 PM
