302 vs 351W
Old Apr 2, 2006 | 08:18 PM
LoosMaster's Avatar
LoosMaster
302 vs 351W
I was doing some cam research when I came across this little piece of info. I've read here about the 351W having more torque than the 302. According to this scale it only relates to it being installed in an F150. The F250 HD, which I put in my truck is way lower. I might have to trash some of the garbage on it. LOL.
Power Availability
Old Apr 2, 2006 | 09:07 PM
MustangGT221's Avatar
MustangGT221
I'm not exactly sure what it is that you're trying to find out...
The 351 has about 40 more ft-lbs of tq than a 302. It has much better low end torque and a better/flatter tq curve across the board.
Old Apr 2, 2006 | 09:22 PM
LoosMaster's Avatar
LoosMaster
https://www.ford-trucks.com/user_gal...112252&width=0
I was trying to put the chart up here but the size limit restriction makes it too small and unreadable. I hope the link goes thru this time.
Old Apr 2, 2006 | 09:28 PM
fordxxx's Avatar
fordxxx
I think I see what you are getting at; the 5.0 has the same 270 lb.ft as the 5.8 and at a lower RPM. Also the HP of the 5.0 is higher. That's wierd eh.
Old Apr 3, 2006 | 03:05 PM
LoosMaster's Avatar
LoosMaster
Yes but only if the 351W is installed in the F150 is it greater. The F250 looses power and torque dramatically. I'm assuming it's because of all the emmisions it has to drive. This engine I have is shadowed by them. You can see all the stuff on it in my '88 gallery.
Old Apr 3, 2006 | 03:37 PM
MustangGT221
Notice the drop in compression...?
I wouldn't put much thought into this...
I don't think it's the emissions stuff...the emissions on the F-250 and F-350 isn't really that much more than the F-150 - its just that those trucks use air injection on the exhaust manifold at each port. It's got a lot of hoses and lines running around the top of the motor. They're not power-robbing stuff...
Old Apr 3, 2006 | 06:45 PM
jroehl's Avatar
jroehl
I'm curious where that chart came from and what years it applies to. There's no way my '90 F150 with its 302 in top condition holds a candle to my '93 F250 and its 351. Not even close. The F250 probably outweighs the F150 by 1500 lbs (xcab vs. reg cab), and I'd bet it would easily outrun it all the way--off the line and in top end, and with a heavy trailer attached. Personally, I'd say that chart probably has some typos--why would the F150/5.8 have MORE torque at a LOWER rpm than the F250HD/F350/5.8? That doesn't make any sense whatsoever.
Jason
Old Apr 3, 2006 | 08:04 PM
LoosMaster's Avatar
LoosMaster
I know, it came from my AllData file for 1988 Ford Trucks. Caught my eye also, that's why I posted it. LOL
Old Apr 4, 2006 | 07:21 AM
MustangGT221
Jason
I duno why, or if it's even true...but the low compression is used on engines that will see heavy loading...so it makes sense that an F-250 has lower compression than an F-150...and it would explain the power change...but who knows...
Realistically it doesn't matter, there's no point in being hung-up by power ratings...they're not accurate anyway. Consider it about 200hp/300tq and call it a day.
Old Apr 4, 2006 | 07:25 AM
LoosMaster's Avatar
LoosMaster
Sounds good. I guess the only way to tell would be to Dyno it.
Old Apr 4, 2006 | 08:21 AM
EgoMan's Avatar
EgoMan
It says f150/f250/bronco and e350 all on the first line so this doesnt mean a whole lot. Fact is you take a bone stock 351 and a bone stock 302 set them up on a dyno and make sure they have the same setup, the 351 is bonna make more tourqe and alittle more power. Its bigger its a fact of life.
Old Apr 4, 2006 | 11:57 AM
LoosMaster's Avatar
LoosMaster
True but the engine I have came out of an F250HD which shows only 180hp and 270 ftlbs of torque vs 210 and 315. That's a big difference in my book.
Old Apr 4, 2006 | 12:36 PM
EgoMan's Avatar
EgoMan
Yea but why would you put it in without altering that first anyway? That would be a waste of time....
Old Apr 4, 2006 | 12:38 PM
Kemicalburns's Avatar
Kemicalburns
i think your reading to much into that document as being the standard. you can make that motor into what ever you want for hp/torque. I to installed a 95 5.8 out of an f250. it scoots compared to the 5.0 that was original in my bronco. i just recently rolled my rig so my drivetrain is getting swapped over to an 85 bronco and at that time i will be installing some jba headers, possible cam (35-255-5) and yanking all the smog equipment off because its not working anyhow, plus its only driven twice a month at most 4x4 only. you will also notice an improvment over what your driven
