random questions
Old Oct 31, 2005 | 01:22 PM
cbfomoco's Avatar
cbfomoco
Originally Posted by fastback69
These are the entries that I had to change on the BIO0 351W computer to run a 6 cylinder.
Scalars
Engine displacement - change to 0.172389
Number of crank degrees per pip - change to 120
Number of cylinders - change to 6
Number of cyl/2 - change to 3
Table
Firing order - change to 1 5 3 6 2 4 0 0
There will, of course, be other things that need changing like the fuel maps, timing maps, mass air transfer, etc. The things I listed above should get it running. Mike Glover, the creator of Tweecer, gave me the info.
any more info on this? what are the advantages or disadvantages? thanks
Old Jan 29, 2006 | 07:48 PM
Dustin M's Avatar
Dustin M
keep in mind that exhaust size should not be more than 2 1/2 inches for a stock or near stock 300
What is the reason for this
Old Jan 30, 2006 | 12:00 AM
optikal illushun's Avatar
optikal illushun
because the exhaust gas velocity will be slowed down to much and low end power loss will happen.
Old Feb 12, 2006 | 03:18 AM
Jefftopgun's Avatar
Jefftopgun
Does the EFI head benifit from the ported and polished head, I was under the impression that it actually took away from the intake velocity, reducing power, or is that only down low?
Old Feb 14, 2006 | 02:08 PM
Jefftopgun's Avatar
Jefftopgun
argh... sooo many questions...So a mild to moderate port and polish, and a 3-5 angle valve job should be all I do, rather than trying to get bigger valves in there?
Old Feb 22, 2006 | 09:33 PM
Jefftopgun's Avatar
Jefftopgun
What year carb head should I look for, are there any big differences, does any head have some extra meat to make a very solid HIGH RPM port? Its got gobs of TQ from the displacement, now show me the power from it.... lol
