Electronic Ignition for 302
Old Apr 2, 2006 | 09:46 AM
hunter1897's Avatar
hunter1897
I have a stock 302 ('71) in my early Bronco now, and am also building a stroker to replace it some time next year. Definitely for the new motor I will have an electronic ignition system, so I'm thinking about upgrading my old/current motor at this time as well. A few questions:
1) What is the difference between the Duraspark and the II and III?
2) Which should I go with?
3) Besides the wire harness, coil, and ignition module, what do I need in terms of distributor parts...do I need an entirely new distributor?
Old Apr 2, 2006 | 10:53 AM
baddad457's Avatar
baddad457
Just get a Pertronix unit and replace the points with it.
Old Apr 3, 2006 | 06:00 AM
ken75ranger's Avatar
ken75ranger
Yes, you will need a duraspark distributor. Your best bet is to grab everything off a donor vehicle. If you don't trust the distributor use it as a core.
