2002 Cd player swap
Old Apr 2, 2006 | 09:02 AM
blackandsilver94's Avatar
blackandsilver94
Question 2002 Cd player swap
does anyone have detail step by step instructions that i could use to swap out my stock cd player with and aftermarket one?
Old Apr 2, 2006 | 12:14 PM
Tiggie's Avatar
Tiggie
You can get a wiring harness from most auto parts stores (I've even seen them at Wal-Mart) that plugs into your current wiring. That should include instructions on what each wire needs to be hooked to in an aftermarket CD Player, and the CD player should have instructions, too. You might try the A/V Forum if you want exact instructions.
Old Apr 4, 2006 | 06:44 PM
blackandsilver94
please!!! any one have a set list of detail instructions
Old Apr 4, 2006 | 06:55 PM
wallingfordr's Avatar
wallingfordr
I have changed mine out and it requires a little modification. The factory player is shaped different and you will have to cut for the aftermarket cd player to slide in all the way.
Old Apr 4, 2006 | 09:12 PM
RangerPilot's Avatar
RangerPilot
You can get a mounting kit from Wally world, as well as the wiring harness. You hook the harness up to your stock system, install the mounting kit, hook the wires up from the harness you bought at Walmart to the one that came with the radio, plug it into the radio, make sure all connections are good and it functions properly, then put it in the truck.
