Help with Radiator size
Old Apr 1, 2006 | 09:08 PM
mmacsek's Avatar
mmacsek
I have a 96 F250 Ext. cab with 351,auto and air. it is 2wd and 8800GVW. The radiator is leaking and I am having problems with the size. I get asked is it 1 or 2 row. How do I tell? I would like the radiator before I take the old one out. I also want a direct replacement with no mods. Any help? Thanks Matt
Old Apr 1, 2006 | 09:17 PM
LoosMaster's Avatar
LoosMaster
If that's the only options, get the 2 row. Pull off the radiator cap(after it's cooled down), look inside and to the left, you'll see the rods that have holes in them. See if you have 1 or 2 vertical rows. Most after market radiators and like a 1 size fits all. You'll have connections for the tranny fluid which have plugs installed if you have a manual one. They're usually aluminum core with plastic end caps.
Old Apr 1, 2006 | 11:16 PM
bohiaa's Avatar
bohiaa
Hay MMacsek (not trying to imply anything here) But did you know if it's not too badly of a leak you can soder it, or have a raditor shop do it for ya...
It may save ya a buck or two
<TABLE cellSpacing=4 cellPadding=0 width="100%" border=0><TBODY><TR><TD noWrap>
</TD><TD width="100%"> </TD></TR></TBODY></TABLE>
Old Apr 2, 2006 | 06:11 AM
mmacsek's Avatar
mmacsek
The radiator is the original(162K miles) and is the plastic/aluminum type. I use this for our business so I don't want a patch. It has multiple leaks. Thanks Matt
Old Apr 2, 2006 | 06:59 AM
water 5's Avatar
water 5
matt
try www.fordtruckparts.com i bought mine from there if you can wait a little on shipment much cheper take a look it is direct fit.
Old Apr 2, 2006 | 07:09 AM
water 5's Avatar
water 5
Originally Posted by water 5
matt
thisis the right web www.frtuckparts.com
