pertonix
Old Oct 5, 2002 | 11:09 PM
john1972f25's Avatar
john1972f25
pertonix
Old Oct 21, 2002 | 06:45 PM
showle's Avatar
showle
pertonix
I have a 1970 ford f-100 with the stock 302...
I've installed a pertronix ignition system on my truck and i was wondering if anyone else has done the same and if so where do i hook the red wire from the ignitor? i dont really know much about the ballast resistor...i hooked the red wire directly tothe battery like the instructions said to do as a test and it runs great so, where is the ballast resistor?
any help would be appreciated
Stuart
Old Oct 21, 2002 | 08:18 PM
1968f100352's Avatar
1968f100352
pertonix
[updated:LAST EDITED ON 21-Oct-02 AT 09:32 PM (EST)]>I have a 1970 ford f-100 with the stock 302...
>Stuart
this Topic #2270 has what i beleave you need. http://www.galaxieclub.com/petronix.html go to this site for complete detail .Look at Pertronix.com under tech support
Old Oct 21, 2002 | 08:40 PM
jkagin's Avatar
jkagin
pertonix
i have a 1972 F250 with a 351W i also installed a pertonix as well as a 6A MSD box along with a Blaster SS coil. love it. works great. as fro the red wire you did the right thing. NO NEED for a balist resistor. it would acctualy hurt the performance. i got this info and help with my instilation from RPM machine shop in Rohnert Park CA.
JK
Old Oct 22, 2002 | 06:30 AM
showle's Avatar
showle
pertonix
so where is the ballast resistor located?
Old Oct 22, 2002 | 05:12 PM
Hawkeye58's Avatar
Hawkeye58
pertonix
It's actualy a resistance wire. It runs from the ignition switch to the
distributor as I recall. The wire is of a proper guage so as to cause
the correct resistance called for. Where as other systems use a resistor
somewhere under the hood to do the same thing.
Hawkeye
Old Nov 18, 2002 | 12:11 PM
GolferSA's Avatar
GolferSA
pertonix
Stock .352, 2bbl... trying to be more fuel efficient, and get better performance. Just picked up the Pertronix Ignitor with high voltage coil, have the 7mm wires on order and installing Splitfire plugs... what is the best recommendation for a cap and rotor to hold up to the increased spark, or is stock ok?
Open to suggestions, thanks!
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
