Dash light replacement
Old Nov 16, 2002 | 06:28 PM
gtex's Avatar
gtex
Old Nov 17, 2002 | 06:13 PM
Kannonball's Avatar
Kannonball
I have a 68 250 Ranger, and the instrument panel lights are gone. (the other dash lights work though, so its not the switch or wiring, its just that theyve burnt out, and the previous owner was too lazy to replace them.)
So I need help in the following.
How in the HELL do you get back there to reach the friggin things, and how many are there?
I keep trying to reach them, and all I get are sore shoulders and back from straining so hard.
Please Help ASAP!!!
Old Nov 17, 2002 | 06:32 PM
Mil1ion's Avatar
Mil1ion
Just remove the cluster and do a complete cluster clean-up and bulb exchange.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 17, 2002 | 06:36 PM
Kannonball's Avatar
Kannonball
I tried that, but the speedo cable wont come loose
Old Nov 17, 2002 | 07:20 PM
rebocardo's Avatar
rebocardo
(if a 67 is the same as a 71) Disconnect the harness assembly by squeezing the top and bottom tabs together. Remove the connector straight out and avoid mashing the fingers on the printed circuit. Pull on the speedometer cable with your hand and move the assembly towards the steering wheel. Do not use the assembly to pull the speedo cable!
You now have enough room to reach the bulbs. There should be five, one behind each directional, three along the top. With a small flashlight you can see little black plastic ***** about 1/2 an inch tall. Each one holds a 194 bulb.
Now you have enough room for a small cresent wrench to fit in there. From the pass. side, turn it top to bottom (counterclock wise if you were facing the back of the panel. If you have to use more than two fingers on the wrench to move anything, something is wrong. Once off, lube the cable!
When putting back the assembly, make sure the printed circuit fingers are lying flat and are not twisted. Put a small amount of anti-sieze on the speedo cable nut. Then plug in the harness, then the cable (making sure you push the cable end into the speedo head before you tighten the nut).
Old Nov 17, 2002 | 08:03 PM
Kannonball's Avatar
Kannonball
Thanks fellas. I got the day off tomorrow, and ill give her a shot.
Old Nov 18, 2002 | 11:24 AM
BB's Avatar
BB
The '68 cluster does not have a printed circuit board nor the big harness connector, it's all hard wired. The bulb sockets pop out from the back side but it's a lot easier if you pull the cluster from the front. The speedo cable has a collar that unscrews. Lay a towel on the steering column so it doesn't get scratched up. Even with the speedo cable disconnected, you can't really pull the cluster out that far. Instead, stick one end of the cluster in the dash hole and the other end of the cluster will stick out. Do the same to get to the other side.
Barry
Old Nov 18, 2002 | 02:04 PM
Mil1ion's Avatar
Mil1ion
This is from a 74 but it is more or less what you will be looking at when you get to it.
http://www.clubfte.com/users/mil1ion/74InstrumentClusterBack.JPG
Dennis
F.T.E. Assistant Administrator
