Head Studs
Old Apr 1, 2006 | 09:52 AM
mech2161's Avatar
mech2161
Head Studs
In the process of installing head studs today. I'll let everyone know how it goes and what I did to get the rear ones in.
Old Apr 1, 2006 | 09:54 AM
PSNut's Avatar
PSNut
As always, we appreciate the info Kevin...Thanks!
Nut
Old Apr 1, 2006 | 10:31 AM
jtharvey's Avatar
jtharvey
Yes, very much appreicated. Hope all goes smoothly.
Old Apr 1, 2006 | 11:23 AM
Kwikkordead's Avatar
Kwikkordead
Yikes! I have visions of having to remove the climate control.
Old Apr 1, 2006 | 12:59 PM
mech2161's Avatar
mech2161
L/S studs are in. Removed 2 L/S motor mount nuts and 2 trans mount nuts. Jacked trans as high as I could (ahead of cross member), trimed insulation on fire wall, placed stud in hole, (with large pry bar) pryed between exhaust manifold and frame and the rear stud dropped right in.
I've got new injector o-rings to install and want to get this side done before I start the other. I'll keep you posted.
Old Apr 1, 2006 | 03:04 PM
Kwikkordead
Wow, that's working around some obstacles!
Question: is there an allen hole in the top of the stud to help snug them down into the block?
Old Apr 1, 2006 | 03:06 PM
jtharvey's Avatar
jtharvey
That was pretty quick. Sounds like you should be up and running by the end of the day!!
Old Apr 1, 2006 | 05:21 PM
mech2161's Avatar
mech2161
Yeh Kwik allen in the top. One side is done, injectors in. Probably do the other side tomorow. I will not have a turbo until next week so I'm in no hurry.
Old Apr 1, 2006 | 05:24 PM
PSNut's Avatar
PSNut
Any pictures?
Old Apr 1, 2006 | 05:35 PM
mech2161's Avatar
mech2161
No Pics. Nothing to it but a lot of time. The left side will be a little tougher.
Old Apr 1, 2006 | 07:44 PM
chevskeezy's Avatar
chevskeezy
if found the easiest way to install them is to blow your engine and put em in when you rebuild the new one, i had to convince the import guy across the street that it was infact a diesel, he says theres no reason to have head studs in a diesel, they cant make enough power to need them he told me. he has no idea what hes talking about when it comes to cars, just what he seen on import shows, a few months ago he told me i was lying about having a v-8 diesel (he was trying to look smart in front of his new girlfriend) "they only make 4 cyl diesels even in semis, my uncle woks on them" the funny thing was, is that he was leaning on my front fender and i pointed down at the POWERSTROKE DIESEL V-8 badge and he shut his mouth. he has no idea that i work on them everyday, or that i know anything about cars. i love to play stupid with him
Old Apr 1, 2006 | 09:06 PM
lukecline's Avatar
lukecline
yeah studs are a breeze when engine is out of truck. My tranny was out when i did studs so i just pulled engine too.
luke
Old Apr 3, 2006 | 07:01 PM
mech2161's Avatar
mech2161
Finished r/s today. It wasn't as bad as I expected. Jacking the motor gave me the space needed but was still tight. I think this way would take less time than raiseing the cab.
Old Apr 3, 2006 | 07:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
cool! so now you can run alot higher boost now? like 50-60psi?
have you upgraded your intercooler pipes and boots yet?
Old Apr 3, 2006 | 07:06 PM
mech2161's Avatar
mech2161
Pipes and boots should hold, no changes yet.
