Offroad & 4x4
Skyjacker
Old Apr 2, 2006 | 09:09 AM
fearfactory's Avatar
fearfactory
Does my 44hd have the flattop knuckles. The truck is at my dads so I cant go and look.
Old Apr 2, 2006 | 09:41 AM
RawPower's Avatar
RawPower
This is a weird axle... It should have the drivers side as a flat top and the pass side not... IF it is the same as a 78 F150 D44
Edit: NM its too early to think... the D44 HD should be the same as a D60 from '78, they do share the same knuckles if I remember correctly. But then again, its early.
Old Apr 2, 2006 | 11:50 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
that doesnt sound right, i dont know of a dana 60 ever sharing the same knuckles with a 44
Old Apr 2, 2006 | 12:00 PM
ivanribic's Avatar
ivanribic
Nope, HD44 and D60's do NOT use the same knuckles. You should be axle to get a machine shop to flat mill the top of that D44 knuckle and then drill and tap once you have the high steer arm. I'd imagine this will cost $100 or so.
Old Apr 2, 2006 | 01:06 PM
fearfactory
I found this on ebay and kinda wanna know if it will for sure work on my 44. It only has 4 hours left.
http://cgi.ebay.com/ebaymotors/flat-...spagenameZWDVW
or what about these
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old Apr 2, 2006 | 01:12 PM
RawPower's Avatar
RawPower
hmm, perhaps I am thinking of D50 knuckles being able to swap onto D60's then?
I dont know what Im thinking anymore...
Edit: BTW you and pro's little stunt of switching avatars is really confusing. Yall have both had the originals for many years up until now. Both of yall switched about a month after I joined... And this is my new theory. The switching of avatars has left me without logic. My brain is lost. ahhhhhhhhhhh
Old Apr 2, 2006 | 01:39 PM
WunTunEarlyBKO's Avatar
WunTunEarlyBKO
yes the 50 and 60 are exactly the same from spindles out but not the 44 or 44HD
Old Apr 2, 2006 | 01:57 PM
KubotaOrange76
yes but the knuckles are not the same
Old Apr 2, 2006 | 02:12 PM
RawPower's Avatar
RawPower
mkay then... oh well. im having a weird weekend and the brain isnt working at all...
Old Apr 2, 2006 | 02:47 PM
KubotaOrange76
that happens to me all the time, matter of fact i dont think its ever really worked right
Old Apr 2, 2006 | 03:56 PM
RawPower's Avatar
RawPower
well yesterday was really weird... welder, plasma cutter, and air compressor all broke. cross threaded 2 bolts, cut myself multiple times with the damn grinder bc i took the guard off bc i bought 5" wheels for it, ours is 4.5"... And lost things within 5 seconds of setting them down.. and... waaaaaaaaaaaaaaaaaa!!!1 WAAAAAAAAA!!!
Old Apr 2, 2006 | 05:03 PM
chrono4's Avatar
chrono4
wow, that was a crappy day, thats when you just call it quits. pro, ivan, knock the crap off, its screwing with my head
Old Apr 6, 2006 | 10:23 PM
  #28
78f3504x4's Avatar
78f3504x4
Originally Posted by fearfactory
Now im totally lossed. I just called 4 Wheel Parts and they said Someone swapped axles in my truck because ford used ttb in 1978 not the solid axle like I have. I'm getting really aggravated with these people considering I spent $3900 on lift,tires,and gears that they said was for my truck.
Ford used a TTB in 1978? Huh?
Old Apr 7, 2006 | 09:50 AM
  #29
KubotaOrange76
thats another reason i stay away from 4 wheelparts....idiots...
Old Apr 9, 2006 | 01:50 PM
  #30
Thomasm67's Avatar
Thomasm67
The help they hire now days
