Block Hugger
Old Apr 1, 2006 | 08:37 AM
BIG66PROJECT's Avatar
BIG66PROJECT
Block Hugger
Can someone tell me if Sanderson block hugger headers will fit in my 66 with a 385 series I found some on ebay
Old Apr 1, 2006 | 11:24 AM
banjopicker66's Avatar
banjopicker66
Big66: If they will fit a 385 in a '70s F-11 - F-250, then yes, they will fit into your Slick.
Remember this: The front portion of the truck, from the front bumper to the rear of the cab is is the same dimension wise from '65 to '79. (I know this applies to 2WD, I don't know about 4x4.) You can bolt up power steering, power brakes, transmissions, engines and all between these years, if you use Ford parts.
For example, I put a 460/C-6 into my '66, and it all bolted up by using Ford perches, motor mounts and the like. Didn't have to drill new holes for the motor mounts, even!
So, it appears the tubes you want will fit, if they are for a '65 - '79 F-100 - F-250.
Old Apr 1, 2006 | 02:22 PM
FordBoypete's Avatar
FordBoypete
Yer' Spot On Banjopicker!
4X2 [aka 2Wd] is exactly the same engine bay 1965 thru' 1979 frame wise. Sheetmetal amongst same models has similar clearance & tolerances generally also.
FBp
Old Apr 9, 2006 | 10:59 PM
headturnin65's Avatar
headturnin65
they fit like gloves........
i run the Sanderson block huggers, and have no problems.
