Edge programmer question
Old Mar 31, 2006 | 11:24 PM
Tony351's Avatar
Tony351
I want to purchase the Edge tuner but I need to know a couple of things.
1. I am planning on putting 35" or 37" tires on my truck. If I recall correctly, the Superchips tuner can only adjust for up to 34" tires. Does the Edge have this limitation or can it calibrate for 35" or 37" tires.
2. How many PRE-tunes does the Edge come with? I remember seeing shift only tunes, tow tunes, and high octane tunes. I would like to use an 87 octane tune but haven't seen anyone mention one. Does it have an 87 octane tune?
Thanks in advance for the responses.
Old Apr 1, 2006 | 12:16 AM
DiscountPowerPrt's Avatar
DiscountPowerPrt
Instructions these are the instructions for the EEF2400. It will answer all your question. Plus there are many threads on this product in this forum.
Old Apr 2, 2006 | 11:54 AM
Tony351's Avatar
Tony351
Thanks for the info but I have one more question not answered in the manual. Can I use the tow tune all the time, even if I'm not towing or will it damage something if I do?
Old Apr 2, 2006 | 11:58 AM
DiscountPowerPrt
No you wont damage anything....that is fine to use all the time.
Old Apr 2, 2006 | 08:17 PM
derek4343's Avatar
derek4343
you can tune it for any size tires.just calculate the format they give you and it will adjust and then give you a new gear ratio also.i also use the tow program and 87 oct. all the time.real nice!
Old Apr 4, 2006 | 11:24 AM
is300wrx's Avatar
is300wrx
what do you mean they give you new gear ratio? I changed the tire size, but didnt change the gear ratio at all...so confused..
