another abs problem !
Old Mar 31, 2006 | 02:46 PM
butchxx's Avatar
butchxx
first post ..like the site!!
2000 ranger 4x4 3.0
ok , when coming to a stop and turning right the abs kicks in. the light does not come on ( checked bulb it works).. does not do it any other time. i did a full brake job a year ago. this just started happening a week ago. today i pulled off rotors and calipers ( even wear) . drums look good and adjusted them a bit. but it still does it. any help would be great!! thanks.
Old Mar 31, 2006 | 02:51 PM
Tiggie's Avatar
Tiggie
So the ABS light comes on when turning right and pressing the brakes? Sounds like a loose wire on one of the sensors. Have you checked all the connections?
Old Mar 31, 2006 | 02:57 PM
butchxx's Avatar
butchxx
the light does NOT come on, but the abs kicks in when it normally shouldn't.
Old Mar 31, 2006 | 03:16 PM
Tiggie's Avatar
Tiggie
Okay.
According to the 2000 service manual, unwarranted ABS activity is caused by either: Circuitry or the Anti-lock brake sensor.
To check the anti-lock brake sensor output, spin the suspect wheel at a constant speed, measure the AC voltage between the suspect anti-lock brake sensor terminals. Is the anti-lock brake sensor output between 100 and 3,500 mVolts? If yes, repair the suspect anti-lock brake sensor circuit(s) in question . If no, replace the sensor.
Old Mar 31, 2006 | 03:21 PM
butchxx's Avatar
butchxx
i'll try that ... lol thanks
Old Mar 31, 2006 | 07:10 PM
Tiggie's Avatar
Tiggie
Apparently, the Ford Tech website doesn't want you to see their pictures. I can email you the picture I had there if you want. Just let me know.
Old Mar 31, 2006 | 09:37 PM
Ken00's Avatar
Ken00
Someone else had a problem with ABS activity at low speeds and it was an damaged front wheel senser.
