1978 - 1996 Big Bronco
Aftermarket CD player
Old Mar 31, 2006 | 01:18 PM
69ford99's Avatar
69ford99
I bought an aftermarket CD player and also have the premium sound system, i'm trying to bypass the factory amp, so I can use the amp built in to th cd player. I have the wiring harness to bypass the amp but in the instructions it says to unplug the input/output connectors from the factory amp and install the wiring harness. Only problem is there isn't two plugs coming off the amp. So I have the bypass harness plugged in on one side but what do I do with the other side? Its plugged into the amplifier harness and the other side is suppose to plug into the speaker inputs but can't seem to find the plug that will mate with the other end of harness.
Old Mar 31, 2006 | 01:29 PM
poffutt's Avatar
poffutt
You should post this in the "Audio radio and electronics fourm. You would get alot more help
