What do I have?
Old Mar 31, 2006 | 11:13 AM
AZmadman's Avatar
AZmadman
What do I have?
My vin# is F10DL615658
WB Color Model Body Trans Axle
115 - M - F100 - 481 - A - 07
Max GVW Cert Net HP RPM DSO
5000 --- 172 --- 4000 --- 24
Thank You in advance?
Old Mar 31, 2006 | 11:26 AM
FordBoypete's Avatar
FordBoypete
Thumbs up
First off Welcome to the 61-66 F Series Forum here at the FTE Website.
You have a Short Wheel Based, 1965, F-100, 2Wd, built mid November 1964 @ FoMoCos' Michigan Truck Plant. An F-100 is a half ton Pick Up Truck.
It has a standard duty, column shift, 3 spd, manual transmission, FoMoCo 9" rear with 3.25:1 gears, a 352 [FE] Regular Fuel Engine w/ 2v carb. It came Corinthiam White. It's a standard cab, as opposed to a Custom Cab or Ranger Option.
FBp
Old Apr 3, 2006 | 12:09 PM
AZmadman's Avatar
AZmadman
Thanks for the info FBp.
