Timing belt question.
Old Mar 31, 2006 | 10:04 AM
Sholou's Avatar
Sholou
Have a question involving the timing belt on a 1994 Mazda B2300. My truck has 154,000 miles on it and it's unknown when the timing belt was done (bought it with 90,000 miles).
Anyways, I was wondering besides the belt itself, is there anything else I would need to buy parts wise for doing it?
Old Mar 31, 2006 | 02:38 PM
Tiggie's Avatar
Tiggie
I don't remember anything else that was required. I do remember replacing the thermostat, because it was right there when you were doing the job, but I don't think it was required. I pulled my raditator if I remember correctly for more room to work when replacing the timing belt. If you decide to pull that, you might want to pick up some extra antifreeze.
I would recommend replacing your water pump at this time if it is the original.
Old Mar 31, 2006 | 05:24 PM
el conquistador's Avatar
el conquistador
remember the timing belt tensioner. and if you take the radiator out plan on a full cooling system flush and new coolant after you do everything else.
