carb linkage?
Old Mar 31, 2006 | 06:13 AM
ford390gashog's Avatar
ford390gashog
carb linkage?
I am going to swap a 300 in my 75 ford truck but i have one issue. How does the carb get hooked up to the pedal? on the 352 thats in there now the carb is connected with a straight rod , but the 300 has a carb mounted way to the left. what kind of adapter do i need?
Old Mar 31, 2006 | 07:41 AM
srercrcr's Avatar
srercrcr
The cable curves around where it is mounted around where the intake meets the valve cover. From there, I suspect you need the factory linkage. Otherwise, you may have binding problems.
Old Mar 31, 2006 | 02:59 PM
ford390gashog
so i need a cable system?
Old Mar 31, 2006 | 05:25 PM
Col Flashman's Avatar
Col Flashman
Yes.
Look in my "Gallery" for Pix.
