Sponsored by: Real Truck
Noise from Pedals
Old Mar 30, 2006 | 03:03 PM
RB_'05 V10's Avatar
RB_'05 V10
Noise from Pedals
Anyone else have a noise/shake/rattle from the gas & brake pedals? My '05 F-250 (CC, 4x4, small box, SWR, V10) has less than 5K miles on it and has had the noise from day one. I've taken it into the deal three times. The first time the dealer said they didn't hear anything. The second two times a different dealer found the noise and was able to tighten some parts, but each time it was only temporary. Anyone else have a similar problem? Have you found a permanent solution? Thanks.
Old Mar 30, 2006 | 03:10 PM
devildog_0431's Avatar
devildog_0431
I'm not sure what kind of Pedal you have but it's mounting brackets could be loosening, they are just little arms that tighten over the metal petal plate. If you Pedal is stock it should just be rubber over the foot plate and the noise would be under the dash more. Check all nuts and bolts and prepare to use some WD-40 if needed. This happened alot w/ my Camaro, of course it was an after-market pedal.
Old Mar 31, 2006 | 02:09 PM
RB_'05 V10's Avatar
RB_'05 V10
Thanks. I haven't had a chance to try, but will.
