ssm 19141--interesting reading
Old Mar 29, 2006 | 06:14 PM
vloney's Avatar
vloney
2003-2004 f-super duty/excursion 6.0 built before 09/29/2003---driveability issues and/or dtc p132b, p006a immediately after reprogramming-service tip after reprogramming a 2003-2004 f-super duty or excursion 6.0l built before 09/29/03 with wds release b41.8 and higher or b42.1 and higher, driveability symptoms and/or codes may occur immediately following the reprogramming. symptoms could include a lack of power, surge, diagnostic trouble code(dtc)p132b or dtc p006a. if these symptoms occur, ensure the following 3 steps were performed per the article directing reprogramming: 1)using a scan tool, record any dtcs, clear kam. 2) perform two key on/key off cycles. 3) ensure vehicle idles at normal operating temp (above 160f eot) for five minutes minimum. this new calibration has greater capability to identify faulty components not previously identified. if dtc or driveability issues are present after following these three steps, follow the updated online pc/ed manual diagnostics. effective date:03/23/2006
Old Mar 30, 2006 | 12:49 PM
Fireferg73's Avatar
Fireferg73
I wonder if mine might need to be done again. I just got my 03 back from the 06E17 recall and when I drove off, it seems the turbo "burped" of few times. Off a stop, it was like the RPM's increased without gaining speed. No CEL light noticed. I reset the odometer at the dealer and when I picked it up it only read 12 miles. I know that they need to drive them more to let components learn strategies. It did it one other time while driving about 35-45 MPH, but now seems to be OK. Idles perfect, starts perfect warm/cold.
I know it's not good to be pesimistic about dealerships/techs/mechanics and the such, but after reading the process involved with doing a flash correctly it's hard not to be. I'm not sure if they removed the FICM relay, or cycled the key as per the instructions. I don't really notice anything different with my truck post recall except for the items above. Total mile since recall = 50 miles
Now I'm worried that it did not get done right the first time.
Ford Fx4
6.7L Power Stroke Diesel
13
Jun 4, 2020 09:50 AM
PowerStrokeHD
6.4L Power Stroke Diesel
21
Dec 11, 2007 04:40 AM
blackhat620
Oct 17, 2007 02:03 AM
scottb1014
2004 - 2008 F150
Mar 29, 2004 05:45 PM
emtabmm
Jan 1, 2004 08:22 PM
