What is wrong???
Old Mar 29, 2006 | 11:51 AM
nonnivett's Avatar
nonnivett
Angry What is wrong???
I have 2004 6.0 and when I start my truck it makes white smoke and the engine dont run normal.
Its like it doesnt run on all cylinders but when I give him some gas he acts normal.
What can be wrong?
Old Mar 29, 2006 | 11:56 AM
DMAX-HD's Avatar
DMAX-HD
Does it act better after it warms up?
Old Mar 29, 2006 | 12:02 PM
nonnivett's Avatar
nonnivett
No it doesnt.
Old Mar 29, 2006 | 12:24 PM
DMAX-HD's Avatar
DMAX-HD
Could be an injector then.
The white smoke suggests your getting mositure in the system from somewhere.
Old Mar 29, 2006 | 04:22 PM
DMAX-HD's Avatar
DMAX-HD
here this may help:
https://www.ford-trucks.com/forums/s...d.php?t=476625
Old Mar 29, 2006 | 06:35 PM
nonnivett's Avatar
nonnivett
Thanks,
this is something I was looking for.Now I will watch this thread and see what they come up with.
But are the injectors most likely to be wrong when he act that way?
Cant this be any electric or computer proplem?
Old Mar 30, 2006 | 06:58 PM
nonnivett's Avatar
nonnivett
Originally Posted by nonnivett
Thanks,
someone
Old Mar 30, 2006 | 07:27 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Have patience, it can take a few days to get a topic going strong.
utahtom's Avatar
utahtom
nonnivett, Ford has excellent diagnostic equipment for the 6.0 which can usually diagnose the problem within 5-10 minutes by performing a series of tests. Bring your truck into the dealer and see what they can find out- It is free of charge if you have less than 36,000 miles or covered under the 100,000 mile warranty with $100 deductable. Good luck
Old Mar 30, 2006 | 10:55 PM
X 03 Jeff's Avatar
X 03 Jeff
Question
I had to jump in here, My tuck has the white smoke, but it does go away after it warms up. Sometimes after the first start up.
Any Ideas???
Thanks for your time
Jeff
Old Mar 31, 2006 | 06:46 AM
GarageDoc's Avatar
GarageDoc
It could simply be condensation in the exhaust. My '04 did it in the AM on the first start-up and by the time I made the first block it was gone. However, if it was continuing to belch white smoke after warm-up I beleive I would take utahtom's advice.
Old Apr 2, 2006 | 07:53 AM
nonnivett's Avatar
nonnivett
I have no mufflers in my exhaust system,Open all the way.
My truck allso is blinking the towing light and I have to switch off to get it away
Old Apr 5, 2006 | 11:02 PM
6.0FX4350's Avatar
6.0FX4350
I haven't been on here in a while because I have been on the road but I came on last night because my truck started to smoke out of the blue yesterday. When I say smoke I mean the some one in the small town I was working in called the local fire dept. Anyway, 2 mile down the road temp went through the roof and called the dealership in the area ... long story short, I am 4 1/2 hours from home with the truck at an unknowd dealership with a truck that has a chip, t-back exhaust, intake and 55,000 miles. I was ready to bend over but the service manager new the problem as soon as he saw it and said it was a faulty coolant line that cools the egr. Also saw the mods and liked the work I've done and said that my performance mods had nothing to do with the problem. Anyway, I have a pos p/t cruiser for a rental and have to drive back 4 1/2 on Monday to pick her up. This particular dealership really suprised me!!!
Old Apr 5, 2006 | 11:09 PM
6.0FX4350's Avatar
6.0FX4350
Coolant is leaking from the egr line and going through the exhaust and turbo, burning up and getting spit out the pipe ... will burn white and not go away. If you run it this way long enough they said you could "hydro-lock your motor" You should notice some type of fall in coolant level after a while but it doesn't take much coolant to make a lot of smoke!
Old Apr 6, 2006 | 08:37 AM
kw5413's Avatar
kw5413
I would get it to the dealer right away.
Could be a # of things. The BM noted below is only one. Moisture is another and possibly ICP sensor.
Have you had all scheduled maint done? Recently?
2003/04 Lack of Power, Runs Rough, Check Engine Light on With EGR Codes:
Some trucks may exhibit exhibit the above symptoms, as well as have excessive white or black smoke, and may have the following EGR valve code(s): P0401, P0402, P0403, P0404, P0405, P0406. Diagnostics for the EGR valve have been updated, as has the EGR valve--P/N 4C3Z-9F452-A. Broadcast Message 3614, SSM 18362.
