96 PSD newb questions...
-Can I fit a 15" rim on the truck without interferance?
-The truck has dual fuel tanks....wondering what size each tank is?
-The truck is equipped with auto locking hubs....I will be changing out to manual shortly...any advice with brands or install tips?
-Any "free mods" that can be done to the truck?
-Advice on a service manual....chiltons, hanes??
Think that's about it for now. I'm going to be troubleshooting a soft brake pedal this weekend, so I'll probably be posting up about that on monday. Thanks!!
Ken
I still have the original factory auto hubs and have never had a problem. If you need to, or are just set on changing them, most people go with Warn and they reportedly supply Ford to begin with.
Free mods - shim the fuel pressure regulator up to about 70 psi; CCV reroute to exhaust (not sure this is needed on an OBS but the ones with ICs do it); heater mod (reduce hot water running when vent or ac is on thus making colder); that is about all I can think of that wont cost much but there are sure to be others.
give www.thedwilsons.com a read.
My long bed has a front 19 gal and rear 18 gal tank. Never run them empty!
I switched my auto hubs to manuals when the truck was new. The dealer replaced them with ford hubs.
Not many "free mods" but there are a lot of cheap ones. I would recomend a Napa 6637 air filter to replace your entire stock intake setup. Then a new 3" down pipe, you can gut the cat for free and the muffler is not restrictive, that helps free up the exhaust. This site has a lot of info to keep you busy.
Good luck with your truck
