Sponsored by: Auxito
2wd Upper Ball Joints
Old Mar 29, 2006 | 02:17 AM
marshall99f150's Avatar
marshall99f150
okay, i went to have my truck aligned and they told me i need new ball joints... okay no plm so i go and buy the joints and the press and start on it... i can't get the top ones out...I got to bottoms by use of a hammer!! that was no problem.. the uppers, how the heck do i get them out??? Pls help!
-Marshall
99 f150 2wd
p.s. this truck has 220,000 miles on it with the original ball joints...
Old Mar 29, 2006 | 03:36 AM
bigdaddyII's Avatar
bigdaddyII
You cant press out the uppers, the whole control arm has to be changed. The control arm complete with ball joints are about the same price as the lower ball joints and a heck of a lot easier to change, try to use Moog parts if at all possible, they are the only ones that allow you to replace the upper ball joint only, and they are proven chasis parts. While you are in there I would see about replacing the inner and outer tie rod ends as well, especially if they are original as well, trust me they need it. I got about 175,000 out of my tie rod ends and ball joints and that was about 50,000 miles to much. Good Luck.
Old Mar 29, 2006 | 04:51 PM
autoparts's Avatar
autoparts
Former Vendor
Moog Control Arms with Ball Joints for the '99 F-150 are about $62 per side at www.RockAuto.com
Old Mar 29, 2006 | 06:07 PM
inlinescott's Avatar
inlinescott
Trailering
A buddy of mine has a 99 F150. He took his truck to a mechanic and they want $900 for replacing the upper and lower ball joints. I have not had to do this on my 93 yet so I'm wondering how hard this is. Any warnings on doing this or is it pretty straight forward? Also is this a defect or is it normal for them to wear out at 100 K? My '93 has 223 K over similar driving conditions and they don't seem to be a problem.
Old Mar 29, 2006 | 06:19 PM
Smaug's Avatar
Smaug
They just wear out faster on the 97-03. I've heard of some being worn out in under 30K. It's a fairly easy job, provided you have a ball joint press.
